W211 Need help with vibration? - Mercedes-Benz Forum : AMG Forums
LinkBack Thread Tools
post #1 of 8 (permalink) Old 03-25-2008, 12:34 PM Thread Starter
Senior Member
Quoted: 0 Post(s)
(Thread Starter)
Need help with diagnosis and will post in W211 too. My 2003 E500 started having a slight vibration when I start the car or have it sitting in Park or while sitting idle at a stoplight. It is more noticeable when I put the car in reverse while backing up slowly.
Once the car is moving the car has no vibration at all. Its not an internal vibration, meaning like an internal engine or transmission part. It feels more like a motor or transmission mount. Something that once there is torque on that part, the vibration goes away, but when sitting idle it causes the vibration.
Any ideas on the earlier W211s if transmission or motor mounts have a tendancy to crack. The other day I needed to hit the gas pretty hard from a start to get ahead of traffic and move over and when I did, I felt a clunk, kind of like what it may feel like if a motor or transmission mount were broken and that torque was causing that part of the car to move more.
Like I said, once driving, I feel nothing at high or low speeds and the car has not lost any power. Just trying to get an idea so I can direct my shop on where to look so they dont start in the trunk and work their way to the front tires for 4 hours of diagnosis?
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
pkancel is offline
Sponsored Links
Advertisement
post #2 of 8 (permalink) Old 03-25-2008, 07:36 PM
Senior Member
First Base
Quoted: 0 Post(s)
Re: W211 Need help with vibration?
anyway bring it to MB dealer to check the transmission and Motor mount maybe there is a crack on the mount. I have the same problem too before and the dealer change the transmission mount and it works great now. Anyway good luck.
Brabus2ner is offline
post #3 of 8 (permalink) Old 03-25-2008, 07:51 PM Thread Starter
Senior Member
Quoted: 0 Post(s)
(Thread Starter)
Thanks much, I plan to take it in, but wanted to see how many have had a similar problem and if most seemed to be transmission or motor mount. Now I can look at the transmission mount myself and see if I can see anything.
Anyone else?
pkancel is offline
post #4 of 8 (permalink) Old 03-26-2008, 10:43 PM
Senior Member
First Base
Quoted: 0 Post(s)
Anyone else?
you are very welcome.
post #5 of 8 (permalink) Old 03-27-2008, 02:32 PM
Member
Quoted: 0 Post(s)
the motor and trans mount are very common problems. i sell them all the time
2008 ARTIC WHITE E350 AMG SPORT PACKAGE | P2 | black carbon fiber trim | H&R springs | 19's hre 843rs brush/chrome lip for sale
olskodumie is offline
post #6 of 8 (permalink) Old 03-27-2008, 04:52 PM Thread Starter
Senior Member
Quoted: 0 Post(s)
(Thread Starter)
The mounts themselves are not so expensive, but any ideas as to range of pricing -to replace Trans Mounts or Motor Mounts
pkancel is offline
post #7 of 8 (permalink) Old 03-27-2008, 05:34 PM
Senior Member
TOW Deletion Advocate
Goliath27's Avatar
Quoted: 0 Post(s)
Send a message via AIM to Goliath27
They replaced mine under warranty but no Idea how much they were, I Assume that would be the problem from what you described. Mine had a Vibration between 70-80mph.
still does it thou.... just not as much
ALi
"rk6400 (7:29:06 PM): what can go wrong"
Goliath27 is offline
post #8 of 8 (permalink) Old 03-31-2008, 04:22 PM
Senior Member
First Base
Quoted: 0 Post(s)
If you are looking to change the motor mount itself is about $700 in the dealer. But for the transmission mount should be much cheaper. Because it is easier to install. Anyway let me know, if you need anything else?
Sponsored Links
Advertisement
Reply
User Tag List
Thread Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
For the best viewing experience please update your browser to Google Chrome
