W211 Vibration problem? - Mercedes-Benz Forum : AMG Forums
LinkBack Thread Tools
post #1 of 4 (permalink) Old 03-25-2008, 01:33 PM Thread Starter
Senior Member
Quoted: 0 Post(s)
(Thread Starter)
Need help with diagnosis and will post in W211 too. My 2003 E500 started having a slight vibration when I start the car or have it sitting in Park or while sitting idle at a stoplight. It is more noticeable when I put the car in reverse while backing up slowly.
Once the car is moving the car has no vibration at all. Its not an internal vibration, meaning like an internal engine or transmission part. It feels more like a motor or transmission mount. Something that once there is torque on that part, the vibration goes away, but when sitting idle it causes the vibration.
Any ideas on the earlier W211s if transmission or motor mounts have a tendancy to crack. The other day I needed to hit the gas pretty hard from a start to get ahead of traffic and move over and when I did, I felt a clunk, kind of like what it may feel like if a motor or transmission mount were broken and that torque was causing that part of the car to move more.
Like I said, once driving, I feel nothing at high or low speeds and the car has not lost any power. Just trying to get an idea so I can direct my shop on where to look so they dont start in the trunk and work their way to the front tires for 4 hours of diagnosis?
Thanks much
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
pkancel is offline
Sponsored Links
Advertisement
post #2 of 4 (permalink) Old 03-26-2008, 01:42 AM
Senior Member
First Base
Quoted: 0 Post(s)
it does sound like motor and/or trans mounts. it is pretty normal for them to go bad depending on mileage, weather, driving characteristics, etc... however it may also be a slight misfire. spark plug wires are very common but there are several other things that may cause the same symptoms. honestly the best bet is to get it checked out and expect 1-2hr diagnosis. anything more than that is excessive.
exit2Ek is offline
post #3 of 4 (permalink) Old 03-26-2008, 03:37 AM
Senior Member
First Base
Quoted: 0 Post(s)
Let me know if u need some help diagnosing.......
sergs99m3 is offline
post #4 of 4 (permalink) Old 03-26-2008, 01:31 PM Thread Starter
Senior Member
Quoted: 0 Post(s)
(Thread Starter)
Thanks much, good to know the motor or trans mount is relatively common. Its not a misfire or engine idle but based on how I described, you are very right it could be. This is a vibration coming from the seats, floor board area and I dont feel anything coming from the gas pedal or anything that would typically be related to engine.
I have to get brakes all around and just ordered everything so good timing to get them put on and have this work done too.
pkancel is offline
Sponsored Links
Advertisement
Reply
User Tag List
Thread Tools
Show Printable Version Show Printable Version
Email this Page Email this Page
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
For the best viewing experience please update your browser to Google Chrome
