top
View previous topic
View next topic
Forum Index C-Class AMG | C55 AMG / C32 AMG (W203)    Page 1 of 1
Post new topic   Reply to topic
Tue Dec 11, 2007 9:14 pm PostPost subject: Heat Exchanger DIY
splinter
n00b
Posts per day: 0.04
2002 Mercedes-Benz C32 AMG
Reply with quote Add to the list of messages to quoteWithdraw from the list of messages to be quoted
Recently fitted an aftermarket heat exchanger to help reduce intake air temperatures and improve performance.
If you are so inclined, it is easy...
Tools required:
wheel chocks
floor jack
jack stands
drain pan
safety glasses
8 mm open end wrench
#20 Torx bit
8 mm socket
10 mm socket
13 mm socket
17 mm socket
ratchets
ratchet extensions
torque wrench (for lug bolts)
pliers/Channel Locks
dykes/side cutters (for pulling, not cutting, plastic rivets)
drill/drill bits
blue masking tape
Optional tools:
work light
drop cloth
shop towels
recycling containers (for old antifreeze)
bin or tray for hardware storage
Optional consumables:
MB #124 990 04 92 under-bumper plastic rivets
MB #002 997 33 86 fender liner plastic rivets
MB #1 03 0002 antifreeze
distilled water
and, of course, refreshing beverages
Safely raise and secure the car -
Apply the blue tape to the bumper/fender junction to help reduce the possibilty of scratching the paint.
Remove the bumper - http://forums.mbworld.org/forums/showthread.php?p=2333330 linked with permission from author
Store the hardware in a bin to aid reassembly -
With the motor cool, remove the drain plug from the radiator and the hoses attatched to the heat exchanger -
Remove the OE unit -
Test fit the new piece -
Note that the overall dimension of the tank is offset somewhat toward the LH side of the car.
When the hose bungs are included, it is relatively centered.
Tank-to-bracket vertical relationship -
Ensure that the fore-aft location of the new heat exchanger does not contact any of the air conditioning equipment that is directly behind.
Wearing saftey glasses, drill the lower radiator support for its mounting hardware, and secure -
Connect the hoses. Open the petcock. Pour some fresh distilled water/antifreeze into the reservoir to help flush any installation induced debris from the system -
Close the petcock. Refill the entire cooling system with a 50/50 mix of MB antifreeze and distilled water. Start the motor and check for leaks. Verify your all work before reinstalling the bumper.
Top off the antifreeze. After several heating and cooling cycles, the intercooler circuit must be properly bled of any residual air pockets -
With the motor cool, remove and direct the vent (yellow) hose into a suitable container. With the aid of an assistant,
have him raise the RPM to just above 3000, while you gently close off of the intercooler fluid return line (red). When only fluid (with no air bubbles) is observed being discharged, you're good to go.
_________________
Back to top
View user's profile Send private message
Tue Dec 11, 2007 9:17 pm PostPost subject: Re: Heat Exchanger DIY
MikeSSw203
Mikey C, MiKey Want
Posts per day: 7.5
2005 Mercedes-Benz C Class
wish I thought of that
Great write up John
Looks like a clean setup/install
_________________
Back to top
View user's profile Send private message   Visit poster's website AIM Screen Name
Tue Dec 11, 2007 10:07 pm PostPost subject:
Ben E55
Broken in!
Posts per day: 1.06
2008 Mercedes-Benz E63 AMG
Well done, thanks for sharing the info!
_________________
Back to top
View user's profile Send private message   Yahoo Messenger
Tue Dec 11, 2007 11:06 pm PostPost subject:
Benzoboi
Post Connoisseur
Posts per day: 11.58
2003 Mercedes-Benz E55 AMG
Very nice write up!!!
_________________
4 door sedan with a couple "go fast" mods and some wheels...
Another great sig brought to you by Shake!
Back to top
Wed Dec 12, 2007 2:43 am PostPost subject:
John 99clk430
Broken in!
Posts per day: 3.91
1999 Mercedes-Benz CLK430
+1
_________________
MichelleSSw204 wrote:
what's the point of having a nice car if you can't drive it.
Back to top
View user's profile Send private message   AIM Screen Name
Thu Dec 13, 2007 4:34 pm PostPost subject:
rlee02135
Addict
Posts per day: 0.76
2004 Mercedes-Benz C32 AMG
Great write-up John! Did you go with a LET or Code3 Heat Exchanger? Is there a noticeable difference after install?
_________________
Back to top
Thu Dec 13, 2007 9:37 pm PostPost subject:
splinter
n00b
Posts per day: 0.04
Thanks, gentlemen. There will be more from the garage soon…
I installed the LET piece since Code3 supplied the anti-roll bar links.
My butt dyno is woefully inaccurate. However, it does indeed feel a stronger kick. Data logging results have thus far been encouraging, with IAT reductions of <30F at WOT. Sanctioned events are next on the agenda. When the debilitating heat of summer is upon us once again, I'm almost certain it will have been a worthwhile investment.
_________________
Back to top
Thu Dec 13, 2007 10:53 pm PostPost subject:
newton
cock
Posts per day: 6.31
Good job man!
_________________
Back to top
View user's profile Send private message [ Hidden ] Visit poster's website
Fri Dec 14, 2007 3:55 pm PostPost subject:
c32used
n00b
Posts per day: 0.01
Awesome Splinter I can't wait to install mine! Any other suggestions? Also thanks again for the sticker you are a gentlemen!
_________________
WE ARE WHAT WE ARE...BUT WE DRIVE WHAT WE ARE OR WANT TO BE
Back to top
Post new topic  Reply to topic    Page 1 of 1
Advertisers/Affiliates Index | Advertising Inquiries
Post new topic   Reply to topic Forum Index -> C-Class AMG | C55 AMG / C32 AMG (W203)
View previous topic
View next topic
Display posts from previous:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
You can attach files in this forum
You can download files in this forum
Jump to:
