ECU Reset:
- Turn the ignition key to the "on" position.
- Press the gas pedal to the WOT position (do not click though) and hold it for 5 seconds.
- Now turn the key to the off position but don't remove the key.
- Release the throttle.
- Wait 2 minutes
Dyno Mode:
- Insert your key and turn to the 1st position
- Press the trip odometer reset button three times.
- The MFD will then display the battery voltage.
- Press either the up or down arrow until you reach a setting for the Dynamometer Test Mode.
- Using the + or - arrow on the steering wheel, choose the test mode.
- The MFD will then display the disabled safety features of the car, including ABS, ESP...
- Start the car and note all safety features are still disabled.
- To reset, either go through the same procedure and turn off Dyno Mode, or simply turn off and restart the car.
- Wait 2 minutes
Dyno Mode:
