http://www.usrecallnews.com/2008/09/nhtsa-1879.html
Mercedes Benz Recall on Models: CL215, CL216, S220, S221, and SL230
September 6, 2008
Make / Models : Model/Build Years:
MERCEDES BENZ / CL215 2001-2006
MERCEDES BENZ / CL216 2007-2008
MERCEDES BENZ / S220 2002-2006
MERCEDES BENZ / S221 2007
MERCEDES BENZ / SL230 2003-2007
Manufacturer : MERCEDES-BENZ USA, LLC. Mfr’s Report Date : AUG 01, 2008
NHTSA CAMPAIGN ID Number : 08V405000 N/A NHTSA Action Number: N/A
Component: SUSPENSION
Potential Number Of Units Affected : 4564
Summary: MERCEDES BENZ IS RECALLING 4,564 MY 2001-2006 CL-CLASS (MODEL 215), MY 2002-2006 S-CLASS (MODEL 220), MY 2003-2007 SL-CLASS (MODEL 230), MY 2007-2008 CL-CLASS (MODEL 216), AND MY 2007 S-CLASS (MODEL 221)PASSENGER VEHICLES EQUIPPED WITH ACTIVE BODY CONTROL (ABC) ACCELERATION SENSORS ON THE FRONT STRUTS. THESE SENSORS MEASURE ACCELERATION AROUND THE Z-AXIS OF THE VEHICLE AND ASSURE AN AUTOMATIC ADAPTATION OF THE FRONT STRUTS TO MAINTAIN A RELATIVELY LEVEL BODY POSITION. VARIATIONS IN THE SOLDERING PROCESS RESULTED IN SOLDERING POINTS ON THE BOARD OF THE ABC SENSORS WHICH MAY NOT BE WITHIN DESIGN TOLERANCES. SIGNALS FROM THE AFFECTED SENSORS MEASURING THE ACCELERATION MAY NOT BE ACCURATELY TRANSMITTED TO THE ENGINE CONTROL UNIT.
Consequence: A VARIATION IN THE TRANSMITTED VALUES BETWEEN AFFECTED AND UNAFFECTED SENSORS CAN RESULT IN ONE FRONT STRUT ADJUSTING TO A VALUE INDICATING BODY MOVEMENT WHILE ANOTHER STRUT DOES NOT ADJUST PRESENTING THE DRIVER WITH AN UNEVEN FRONT SUSPENSION. THIS CONDITION MAY LEAD TO UNEXPECTED BODY MOVEMENTS AT THE FRONT AXLE WHICH CAN ADVERSELY INFLUENCE THE VEHICLE’S DIRECTIONAL STABILITY AND COULD LEAD TO A VEHICLE CRASH.
Remedy: DEALERS WILL INSPECT AND REPLACE, IF NECESSARY, THE FRONT ABC SENSORS IN ALL POTENTIALLY AFFECTED VEHICLES. THE RECALL IS EXPECTED TO BEGIN DURING SEPTEMBER 2008. OWNERS MAY CONTACT MERCEDES-BENZ AT 1-800-367-6372.
Notes: CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO
HTTP://WWW.SAFERCAR.GOV.
ALi
